ZYX 3-Axis Flybarless System (Hobbyking, tarot) - CX-3X1000
The Hobbyking ZYX high performance multi-function 3-axis gyro system is the lightest flybarless system in the world. It is compatible with all 200-700 nitro or electric power helicopters and support 90, 120, 135, and 140 degree CCPM swashplate systems. Furthermore, it is compatible with all types of servos; supports both digitial and analog 1520us, 960us and 760us servos. The setup process is quite easy, takes only about ten minutes. This unit also supports firmware updates.
ZYX 3-axis gyro system provides two different flight modes - F3C and 3D, which can satisfy pilots from beginners to advanced. ZYX 3-axis gyro system has many adjustable options; pilots can adjust the parameter of swash plate and tail servo response, which allows the user to fine tune the handling characteristics of the helicopter.
ZYX high performance 3-axis gyro system uses MEMS gyro sensors which allow the pilot to control the flying status of helicopter precisely. Built-in pirouette optimization function; stabilizes the helicopter while pirouetting, making the advanced manuevers much more precise.
*Note: We have tested this unit on our HK450PRO and are very impressed with the performance. The ZYX flybarless system is an unbelievable value at a fraction of the cost of other systems currently on the market.
Specs:
Weight: 9.8g (without wires)
Operating Voltage: 3.5~9V
Sensor Technology: 3 MEMS angular rate sensors
Flight Modes: F3C / 3D
Included in box:
English user manual
5 gyro mounting pads
All necessary wire leads
http://www.hobbyking.com/hobbyking/stor ... duct=20996
CX-3X1000
Specification:
Operating Voltage: DC 3.5V-9V
Operating Current: 60mA
Operating temperature: -10°C -50°C
Maximum angular rate: 800 degrees / sec
Support the rudder servo: 1.52ms analog servo, 1.52ms digital servos, 760us digital servos, 960us Digital Servo
Support the swashplate servos: 1.52ms analog servo, 1.52ms digital servo
Weight: 26g (including cable and plug)
Dimension: 38.2*26.2*13mm
http://www.ehirobo.com/shop/product_inf ... s_id=11109
manuel: http://www.ky-model.com/copterx/cx-3x1000_manual.pdf
CX-PB001 Program Box:
Features:
Detail setup for CX-1Xx1000 and CX-3X900 gyro
No laptop or external battery necessary
Quick setup at flying field
Compact, durable aluminum case design
Can be use as Lipo, receiver battery checker from 1-8S
Servo tester to test speed and operation
Specification:
Operating voltage:
Data port: DC 4.8V-12.6V
Servo port: DC 4.8V-12.6V
Servo power: DC 4.8V-12.6V
Battery measure port: 4.8V-33.6V2-8S Li-Po, Li-Ion, Li-FePO4, Li-Mn
Operating current drain: 150mA
Operating temperature: -20-70
Servo compatibility: 1.52ms analog servo, 1.52ms digital servo, 760us digital servo
Supporting firmware upgrade
manuel: http://www.walkera-heli.com/manual/cx-pb001_manual.pdf
moi qui en cherchai un hop commandé pour le prix je risque pas grand chose!
par contre les test ne seront pas pour tout de suite je n'ai plus de radio...
Specs:
Included in box:
English user manual
CX-3X1000
Specification:
Features:
Specification:
Operating voltage:
Modifié en dernier par blacline le 13 déc. 2011, 04:00, modifié 8 fois.
On peu reprocher beaucoup de chose au chinois, mais eu au moin ils bouffent leurs chiens!
Turnigy 9x er9x frsky version
- Gillou30
Re: Hobbyking ZYX 3-Axis Flybarless System
j'ai un pote qui en a une, ça marche sans soucis....
Gillou
Gillou
Logo 600+spirit -Kasama nitro+Vbar- Logo700+neuron- DX10- Phoenix et neXt (quand j'arriverai à le paramétrer!! maintenant ça marche, c'était mon ordi qui ramait)
J'ai pris celui là:
D'après ce que j'ai vu sur le net, la carte électo est la même.
Blade 130X Mini Protos Microbeasté : la maxi-teigne
Compass 6HV Microbeasté Futaba T8FG 2.4GHz
Maxi swift FPV Turnigy 9X flashée er9x + Scherrer UHF
YO
Le Hobbyking ZYX haute performance multi-fonctions du système gyroscopique 3 axes est le système le plus léger flybarless dans le monde. Il est compatible avec tous les nitro 200-700 ou des hélicoptères d'énergie électrique et de soutien 90, 120, 135 et 140 degrés CCPM systèmes plateau cyclique. Par ailleurs, il est compatible avec tous les types de servos; supporte à la fois 1520us Digitial et analogiques, et les servos 960us 760us. Le processus d'installation est assez facile, prend environ dix minutes. Cette unité prend également en charge les mises à jour du firmware.
Système de ZYX gyro 3 axes, offre deux modes de vol différents - F3C et 3D, ce qui peut satisfaire les pilotes de débutant à avancé. Système de ZYX gyro 3 axes, dispose de nombreuses options réglables; les pilotes peuvent ajuster les paramètres du plateau cyclique et la réponse servo, ce qui permet à l'utilisateur d'affiner les caractéristiques de manipulation de l'hélicoptère.
ZYX haute performance gyro 3 axes, système utilise des capteurs gyroscopiques MEMS qui permettent au pilote de contrôler l'état de vol de l'hélicoptère avec précision. Built-in fonction d'optimisation pirouette; stabilise l'hélicoptère tout en pirouettes, ce qui rend les manœuvres avancées beaucoup plus précis.
* Note: Nous avons testé cet appareil sur notre HK450PRO et sont très impressionnés par la performance. Le système ZYX flybarless est une valeur incroyable à une fraction du coût d'autres systèmes actuellement sur le marché.
Spécifications:
Taille: 37x25x13mm
Poids: 9.8g (sans fils)
Tension de fonctionnement: 3.5 ~ 9V
Sensor Technology: 3 MEMS capteurs de vitesse angulaire
Modes Vol: F3C / 3D
Compris dans la boîte:
Manuel utilisateur en anglais
5 gyroscopique de montage coussinets
Tous les fils nécessaires mène
Merci delse31 je viens d'annuler ma commande!
Au passage c'est très vite fait avec le chat live de hk.
Je vais éditer un peu le post pour mettre les différente versions.
Gillou, tu parles duquel ?Gillou30 a écrit :j'ai un pote qui en a une, ça marche sans soucis....
Gillou
MA CHAINE VIDEO
------------------------------------The Meeting Heli4 2013-2014..., j'y étais!!! -------------------------------------------
Salut, je l'ai acheter hier soir chez HK avec la tête fbl RJX (copy du RJX?? les chinois qui copy les...chinois ) et j'espère avoir le coli avant noël.
Re: ZYX 3-Axis Flybarless System (Hobbyking, tarot) - CX-3X1
vous trouverez des photos du boîtier ouvert ici:
tarot, hk:
http://www.helifreak.com/showpost.php?p ... tcount=133
cx-3x1000:
http://www.rcgroups.com/forums/showpost ... stcount=14
tarot, hk:
cx-3x1000:
program box en stock chez ehirobo!
Petit retour (copier-coller de ma page perso)
D'abord, le contexte: L'hélico est un CX250 upgradé(si on peu dire) Align. Il a déjà vachement chargé le bestiau
La tête est une mico-héli retapée comme j'ai pu, et l'AC est un Align (gavé de jeu quoi ! )
Donc la tache n'est pas simple pour ce petit module.
Retour sur les régalges: Je l'ai fait sans, mais le boitier de prog s'impose si on veut faire quelque chose de sérieux.
Le réglage de certaines valeur, sans, est un peu chiant. On sait si on l'augmente ou la diminue avec les leds mais on ne connait pas la valeur. De plus le boitier permet d'acceder à plus de régalges: gain dérivé ,etc..
Ce qui n'était pas top: un peu d'oscillation à l'AC sur les gros coup de pas et les arrets : J'ai eu la flemme de le régler plus finement (trop chiant) et un très petite dérive au ailerons (Surement des virbations à l'AC + une mousse trop fine pour pouvoir le faire rentrer dans le 250). Il faut que j'y passe un peu de temps, mais ça devrait pouvoir se corriger facilement.
Par contre ça marche quand même super bien (malgré la merde sur laquelle il est installé). J'ai fais grosso modo la même type de vol que celui du miniP d'hier (je sais : je suis dans ma période crade )
En statio l'AC ne bouge pas d'un poil. Les translations rapides ne m'ont pas semblées bien différentes du MB.
Les flips sont nickel, pas de décallage aux ailerons, les rainbows itou, pas de soucis dans les funnels même rapides.
(Pour info je ne sais faire que le funnels favorables à l'AC)
C'etait la merde dans les pyros, mais bon ... Qui incriminer ?
conclusion: Validé !
Ca mériterait bien sur un test sur une machine un peu plus en ordre. (et un pilote plus mieux itou )
Par contre pour 30€ livré, on va vivement le conseiller aux débutants du club (pas facile de trouver un simple gyro sympa à 30€).
Bon, qui se dévoue pour le monter sur un miniP ? (J'ai la flemme)
merci pour ton avis delse31 qui me rassure! Surtout que je m'en suis commander un 2e pour mon 250 avec la program box.
voici 2 photos a coter du hk401b:
- Dany Boy
Idem j'ai commandé le module et la program box.
Ce sera monté sur le T500 vol de nuit.
Si ça marche,c'est bien,sinon poubelle.
- Dany Boy
Module réceptionné,y a plus qu'a sortir le 500 pour peut être faire un vol...............la nuit de noël
tien nous au courant!!
J ai enfin reçu ma nouvelle radio et fini toutes les modif, je vais enfin pouvoir au réglages de mes heli
- Dany Boy
J'ai fais les réglages a l'aide de la Program Box,c'est relativement simple.
Premiers statios éffectué,je ferais mes premiers vol cette semaine..........peut être,car madame m'a offert un MB!
- Dany Boy
Bon je comptais viré le CX3X1000 et monté le MB directement,mais en y réfléchissant et a la demande de plusieurs pilotes connu du forum,j'ai décidé(avec l'accord de madame ) d'approfondir les tests du CX3.
Donc je reviens a l'instant du premiers testen extérieur.
Les conditions tout d'abords:
-L'hélico,un CX 500SE V2,tête fbl et AC complet Align,3 turnigy MG930 et 1 DS520,des pales de me.de,moteur turnigy typhoon 500 et esc turnigy plush 80A.Bref,un hélico loin d'être au top
-Le site de vol,la cours de mon magasin,qui fais 15x25m
-Les conditions,au top,je prend mon hélicodans l'appart a 24° et je le fou dehors a 0° et je décolle direct(là y a de l'acclimatation)
Premier décollage,il faut trimmer un peu car il dévie(j'ai réglé a l'oeil le plateau),bref je pose,branche la box de prog,et je retouche au point par point avec des repères numérique.Là je dois avouer que c'est pratique,ça fais des points de repère.
Redécollage,et là c'est top,c'est stable,l'ac ne bouge pas d'un poile en HL(je n'ais pas réglé le neutre)
L'hélico dandine un peu mais un T-500 avec 60% de gaz,c'est pas non plus extraordinaire de voir cela.
Les réactions au manches sont ultra vive(mode 3D utilisé sur la box)j'ai fini par mettre 40% d'expo partout,l'Ac en redemande encore.A savoir que sur le MB j'ai 25 d'expo et 40 a l'Ac sur tout mes hélicos.
Sur les pirouettes,l'Ac rebondi trés légèrement,le cyclique dévie trés peu.
Deuxième lipo,j'ai modifié ma courbe de gaz a 70% et monté le gain Elev et Aile(toujours point par point comme un gain sur une radio)car l'hélico cabrais un peu sur la mise de pas.
Rien qu'au décollage,l'hélico ne glisse plus,en statio,c'est plus stable et ne dandine pratiquement plus.
Il manque encore des tours et de gain cyclique mais c'est déja beaucoup mieux.
Il faudrais que je regarde pour mettre de la précompensation d'Ac car il décroche un poile sur la mise de pas.
Voila un peu les premiers retour en attendant de pouvoir faire un vrai vol en translation,puis faire de la voltige.
Mes impressions quand même,le MB reste là référence pour moi,au premier vol avec lui ça marche et je ne tarderais pas trop non plus a le monter sur le 500.
Mais je pense qu'on peut avoir quelques chose de "correct" pour celui qui voudra monter une machine a pas chère,ou pour du vol tranquille type maquette,si on prend la grande patience de le régler,et surtout si on a les connaissances requise pour régler tout ce bazar.
Merci pour le retour Dany, quand on prend l'excellence du MB comme référence, cette petite chinoiserie a l'air plutôt correcte
MA CHAINE VIDEO
Merci Dany Boy pur le test!
hier j'ai commencer a régler mon 250 avec une tête fbl tarot avec ça on verra si il est efficace! mais il me faudra un peu de temps pour comprendre ma new radio.
- Dany Boy
Second test cet après midi.
Cette fois j'ai pu faire des translations,il se dandine sur la profondeur,il faudra baisser le gain cyclique.
Et surtout virer mes me.de de lipo chinetok qui tire pas un caramel et qui au bout de 2 minutes ressemble plus a des patates brulé qu'autre chose,mais ça c'est un autre problème.
Les gars du club ont été étonné de voir un 500 avec un module a 2 sou,et il y a fallu insister pour qu'il me suivi sur la piste
Ca vol ton machin t'est sure?
A ce prix là?
Mdr,donc j'ai translaté un peu,puis il m'ont dis,viens voir les arrêts d'AC?
Vache ça verrouille
Bon,je me suis dis,on va le foutre sur le dos même s'il tire pas un caramel et qu'on dirais une 2 chevaux ,bas les flips passe correctement,ça manque de débatement je pense,mais il verrouille bien au cyclique donc voila.
Je vais recommander des lipos et je ferais les vols de rodages lipos le temps d'affiner un peu,et quand ça volera correctement(si ça arrive) je vous ferais une vidéo avant démontage et passage au MB
A ce prix là?
Vache ça verrouille
YO D.B,
Merci pour le partage...
Et voici quelque vidéos:
250:
http://www.youtube.com/watch?feature=pl ... uxJKiCkzTE#![/video]
http://www.youtube.com/watch?feature=pl ... kT_yGIIqGs#![/video]
450:
http://www.youtube.com/watch?feature=pl ... kG_PHJEPVw#![/video]
600:
http://www.youtube.com/watch?feature=pl ... 8bJ-DE1xUo#![/video]
250:
450:
600:
Âpres pas mal de temps a modifier ma turnigy 9x et a apprendre a m'en servir, je suis enfin passer au réglage de mon hk250gt.
J'ai essayé de partir sur de bonne base bien que c'est pas le top vu les servos que j'ai dessus...(Turnigy MG90S,HK-922MG)
bref g passer pas mal de temps pour les réglages mécanique il est au poil!
2, 3 petit décollage pour régler les différents gains et je me retrouve avec un hélico vraiment stable en statio (juste tester en intérieur) et la tail ne bouge pas.
la program box me semble indispensable elle simplifie grandement les réglages, surtout pour le prix.
Si un pro pouvait faire un test complet se serait top!
Perso g pas le niveau mais je pense que c'est un bon gyro pour débuter en fbl pour pas chère!
- Dany Boy
J'attend mes nouvelles lipos pour y secouer un peu plus.
Je vous dirais ce qu'il en est............si je ne remonte pas le BeastX avant!
- Dany Boy
Quelqu'un sait il si la clé USB Tarot fonctionne sur le module CX?
Je ne connaissais pas se cable usb.
j'ai fait quelque recherche et il y a une version patcher du logiciel qui est compatible avec le cx-3x1000 et l'alzrc.
Ils en parlent ici mais le lien pour le dl est hs:
http://www.rcgroups.com/forums/showthre ... 79&page=39
Salut a tous !
J'ai bien envie de me prendre un cx 3x1000 pour mon copterX 250
Mais j'hésite entre la program box et le clé usb (ya quand meme une belle différence de prix ).
La program box est vraiment essentielle pour les reglages sur le terrain ?
Merci de vos reponses
Pour le prix le câble est un minimum ça c'est sur!!
Le soft a l'air complet, avec pas mal de photo qui me semble pas mal du tout.
Après la box permet de tester ces lipo et servo en plus, je trouve aussi plus pratique de pouvoir faire mes réglages sans pour autant avoir un pc a coter.
La box te permet effectivement aussi de peaufiner un peu tes réglages sur le terrain mais si ton gyro est bien régler la box n'est pas indispensable.
Merci de ta reponse
Donc pour regler les gains sur le terrain c'est indispensable ? Avec les manches on peut aussi non ?
salut a tous,
j'ai fait l'acquisition il y a peu de temps d'un tarot 450 avec le module tarot zyx et j'ai quelques réglages de finition a faire et je me vois mal me baladé avec mon pc sur un terrain.. la program box dont vous parler qui est de marque copter x marche aussi pour le module tarot?? et y a t-il une notice en français inclus avec car moi et l'anglais sa fait environ deux, mais avec le chinois sa doit faire environ douze..
merci d'avance.
cordialement, bibi
merci d'avance.
cordialement, bibi
florent, lisieux, 24ans
BI:alloy shark 006 (mulet!!)
BI:lama 400D(brushless[va etre a vendre])
BI:lama 2#1(bijoux d'appartement[va etre a vendre])
CP: blade mCPx v2(mon ptit moustik bien vivace!!)
cp: tarot 450 fbl zyx
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
"c'est pas la chute qui fait le plus mal... c'est l'atterrissage"
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
je suis moi aussi l'heureux propriétaire d'un module Tarot ZYX pour mon Tarot 450 Pro. En revanche je rencontre un souci qui me donne pas l'envie de le faire décoller, en effet, en statique et après réglages via le logiciel, quand j'agis sur le manche des gaz le plateau ne monte pas droit et ne descend pas droit... J'ai changé les servos (MKS DS470) pour des MKS DS92 et toujours le même souci.
Dans la radio (Futaba T10) je suis bien en mode H1, tous les mixages sont désactivés. Est-ce que pour vous ça faisait ça aussi en statique ou alors vos plateaux montaient bien droit ? J'ai bien opté pour de servos digitaux à 1520ms et servo AC de 760 ms (MKS 8910A+) dans le logiciel. Mes neutres mécanique sont bien faits.
Question subsidiaire: avez-vous fait un neutre méca à 0° pour l'AC ou bien à 8° comme le préconise la doc ?
Tarot 450 Pro Flybarless: Moteur Scorpion 2221-8 V2 & CC Ice 50A - Radio Futaba T10 CHG 2.4 Ghz - Tarot ZYX -Servos MKS DS92 & MKS 8910A+
Finalité, c'est le potard de profondeur sur ma T10 qui est mort...
salut la compagnie,
quelques questions sans reponses me font venir a vous, j'ai reçu la clé usb qui sert a pofiner les réglages de ce gyro, mais y a t'il des choses a savoir avant que je connecte l'ensemble a mon pc ( remise a zéro invoulu au branchement usb ou quelques réglages a faire..) j'ai peur de faire une boulette ou dérégler quelques chose..
merci d'avance..
merci d'avance..
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
tu peux y aller, tant que tu ne demandes pas de reset toit même et que tu ne valide pas une modification, rien ne sera modifier.
Les réglages via le logiciel est vraiment sympa et facilite grandement les choses.
Merci beaucoup de ta reponse je vais me pencher la dessus se soir alors...
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
Je viens aussi de finir de monter mon ZXY sur mon 450 Sport, équipé d'une tête RJX.
Le premier vol est pour ce we je pense
Pour info, au niveau du branchement du module avec le câble USB, j'ai eu quelques soucis de connexions.
En gros la connexion ne fonctionnait plus.
Le truc est de désinstaller le driver USB, puis de le réinstaller.. et c'est ok.. <_<
Henseleit TDR / Outrage 550 Spektrum dx6i / dx7
Sukhoi 31 / P-47 / Swift 2 / SuperZoom 2 / Petit Chelem / FW-190 .60 (to build)
«Chaque décollage est facultatif, les atterissages par contre...»
salut a tous, j'ai tout essayer je n'arrive a connecter le module a mon pc via la clé usb ...
j'ai la version 1.16 (beta) me faut-il une version plus récentes de ce logiciels pour que cela fonctionne??
merci a vous d'avances pour votre aides.
florent
florent
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
- ruf86
Je vous conseille l application de john_NZ dispo sur son site (compatible CX3 et ZYX)
Http://fbl.net.nz/
Installez la,
Ensuites choisissez le port com qui correspond à votre d'ongle USB (moi c est COM10 par défaut, vous pouvez vérifier dans votre gestionnaire de périphérique )
Ensuites allumé dans l ordre :
Radio, gyro et cliquez sur "connect" et le tour est joué.
Http://fbl.net.nz/
Installez la,
Spektrum DX6i Mode 3
merci a toi ruf86 j'ai pu cliquer sur la deuxieme version dispo sur ce site qui me donne accès a une version 1.21, surement une amélioration de la 1.16 que j'avais... je testerai un soir vous dire si cela fonctionne..
merci, flo
merci, flo
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
simuhoenix 2.5
chargeur:imax b6
radio:spektrum DX7
autres:windows 7
furetons a vendre
une nouvelle version est sorti:
Features:
Support DSM2 and DSMJ satellite receiver.
Support Futaba S-Bus.
Support failsave programable when user using DSM2 and DSMJ satellite receiver. User can set the failsafe values for throttle and collective pitch.
Support four aircraft configrations: ‘+’type quadcopter, ‘X’ tyep quadcopter, fixwing airplane (enhance hover and 3D flight), deltawing aircraft.
Support pc link. User can program it via PC software.
The ZYX 3.0 PC software add parameter explanation function. Just put the mouse on the parameter,the explanation will be shown on screan.
http://www.infinity-hobby.com/main/prod ... ts_id=8201
voici un page qui explique bien tous les reglages:(en anglais)
http://www.toyrecycler.net/?p=23279
Features:
