Firmware DX8
TiTidom
Re: Firmware DX8
Message par TiTidom » 15 août 2012, 10:19
Hello :)
Merci pour l'info, je viens d'aller voir, le changelog n'est pas neutre (dans le sens "fourni") :p
En voici une copie pour info :
Code : Tout sélectionner
Version 2.05
13 August 2012
Software Features
• Added support for GPS and High Current telemetry sensors.
• Enabled up to 32-pole motors for the brushless RPM sensor.
• Enabled SD telemetry log file
• Enabled ability to configure inactivity timer
• Enabled backlight configurability (Auto/On/Off)
• Enabled dimming control of the orange Spektrum LED for night flying
• Adjusted vibe motor RPM to be less aggressive
Software Corrections
• Fixed bug that could reset the radio when scrolling through Mix options.
• Corrected L/R trimmer ‘forgetting’ assignment after power cycle.
• Improved translations in French and Italian screens.
• Corrected export of flap configuration.
• Corrected over-travel of flaps that could result in reversed operation at extreme
deployments.
• Corrected switch change on Acro throttle cut screen when going from the initial
switch selection to the edit page.
• Corrected timer to work properly in Throttle Out mode when using reversed
throttle channel.
• Corrected end-point adjustability when Trainer is used as an input to a channel.
• Corrected trainer normal Master mode so that it doesn’t modify controls from the
slave. In previous versions it could reverse channels vs. what was expected.
NOTE: This change affects sub-trim and travel of existing models and ones you
will import. You may need to adjust sub-trims and travel on all control surfaces in
both airplanes and helicopters.
@zamels : oui, je suppose, d'après le changelog, ca l'enregistre sur la carte SD, à tester :lol:
Image TiTidom (92) 37 ans Image DX8 (v3.00 / M2) - Spot de St-Nom (Yvelines) (Accès)
Image QAV 400 & 540G NAZA V2 / DJI F330 OP Révo Image TRex 450Pro & 550E FBL
_____________________________Image_____________________________
methos68
Re: Firmware DX8
Message par methos68 » 15 août 2012, 11:04
mais du coup il faudrait un logiciel pour interpréter les infos ?
sacré maj en tout cas.
godjc
Re: Firmware DX8
Message par godjc » 15 août 2012, 12:43
Oui exactement. reste à savoir quand ils vont sortir le logiciel pour exploiter ces données et surtout qu'est ce qui est enregistré.
Image - Gaui NX4, servos cyclique : DS515M, servo AC : Align DS525, gyro : Msh Brain, moteur : TT 53 (En vol)
Image - Goblin 500, servos cyclique : BK 5001, servo AC : BK 7001, gyro : Eznov Neuron, moteur : Quantum 4120 (En vol)
Image - Align 700N, servos cyclique : HBL665, servo AC : MkS HBL669, gyro : Msh Brain, moteur : OS 105HZ (En vol)
Image - Spektrum DX9
Image - Chargeurs : Icharger 106B+
Image - Libelle F3K
[email protected]
Re: Firmware DX8
Message par [email protected] » 18 août 2012, 07:02
Bonjour , concernant les mises a jour , êtes vous prévenu via un mail de spektrum ou vous allez jeter un oeil de temps en temps ?
Ma flotte :
manulight
GAYnille
Re: Firmware DX8
Message par manulight » 18 août 2012, 08:44
J ai un pote qui vient de faire la maj et il est revenu en arrière aussitôt car pas mal de souci ...
Qlq à essaye ?
PaPaYoU
Re: Firmware DX8
Message par PaPaYoU » 18 août 2012, 08:47
Oui moi depuis 3 jours aucuns soucis de mon côté ;)
PaPaYoU
Re: Firmware DX8
Message par PaPaYoU » 18 août 2012, 08:50
Il faut faire attention à ca:
[email protected]
Re: Firmware DX8
Message par [email protected] » 18 août 2012, 08:52
Pas de soucis chez moi , juste quelques trim ou neutre a régler .
Ma flotte :
renaud67
Re: Firmware DX8
Message par renaud67 » 18 août 2012, 08:52
manulight a écrit :J ai un pote qui vient de faire la maj et il est revenu en arrière aussitôt car pas mal de souci ...
Qlq à essaye ?
http://www.france-helico.com/viewtopic. ... 29&t=43666
PaPaYoU
Re: Firmware DX8
Message par PaPaYoU » 18 août 2012, 08:55
Qlq à essaye ?
Je n'ai pas ce problème je viens de vérifier
et pour les trims chez moi ils sont désactivé car j'utilise du beast X
Herse
Re: Firmware DX8
Message par Herse » 18 août 2012, 11:04
Je n'ai pas eu de problème après la mise à jour. Mais pour toutes mises à jour je vérifie toujours si il n'y a pas eu de changement dans mes réglages.
Sh.
DX8, DX6 & Er9x mode 2|Phoenix RC v4|Imax B6 + Transfo 35A|Blade mCX2/120SR/mSR/mSRX/mCPX v1&v2/ mQX/130x/300x
Ar Drone V1 en mod RC|Gaui 330x-Gu-ins|SpyHero & Naza V2 +iOsd+ Gps|T-Rex 250 SE|Logo 500se
Tedarg
Débutant
Re: Firmware DX8
Message par Tedarg » 18 sept. 2012, 19:43
Bonjour, pour moi, la mise à jour de la version 2.05 me pose un gros problème de fonctionnement de l'écolage.
La voie 6 du pas n'est plus mixée en écolage hélico avec un plateau cppm 3 servos 120°. J’attends une réponse de Spektrum sur ce sujet.
En attendant, retour à la version 2.04 !!
Trex 700 Nitro DFC
Trex 550 DFC
Raptor 550E FBL
Gaui NX4
Shuttle ZXX
Trex 450 PRO DFC 3GX
Trex 250 PRO DFC 3GX
Zoom 450 Nitro
DX18 Spektrum
[email protected]
Re: Firmware DX8
Message par [email protected] » 20 sept. 2012, 05:57
Tedarg a écrit :Bonjour, pour moi, la mise à jour de la version 2.05 me pose un gros problème de fonctionnement de l'écolage.
J'ai aussi ce probléme d'écolage ( avion ) .
Sur deux dx8 , il suffit de copier le model de l'une sur l'autre via la carte et ca marche .
Pour les autres radios qui ne possedent pas de carte mémoire il faut créer un profil identique avant de brancher le cable .
C'est devenu laborieux , avant je branché et ca fonctionné .
Ma flotte :
renaud67
Re: Firmware DX8
Message par renaud67 » 26 sept. 2012, 17:28
DX8 Version 2.06:
Software Features:
Automatically corrects sub-trim and travel for models created in version 2.04 and earlier after prompting the user. This is functional both for models already in your radio, and for any you import from an SD card. You should always verify operation of a model when making any updates prior to flying it.
Software Corrections:
P-Link Master Trainer mode was using trainer data for channels GEAR and higher.
When a channel is reversed the endpoint adjustment worked on the opposite side from what was expected.
Improved French translations.
Added SD logfile indicator to main screens.
NOTE: This change affects sub-trim and travel of existing models and ones you will import. You should double-check sub-trims and travel on any reversed control surfaces in both airplanes and helicopters when using models created in version 2.04 and earlier.
http://publications.horizonhobby.com/re ... x=f361e219
godjc
Re: Firmware DX8
Message par godjc » 26 sept. 2012, 21:43
Bonsoir, nouvelle version 2.06
Image - Libelle F3K
Tedarg
Débutant
Re: Firmware DX8
Message par Tedarg » 27 sept. 2012, 08:35
enfin , cette nouvelle version corrige tous les problèmes de la 2.05.
Trex 700 Nitro DFC
Trex 550 DFC
Raptor 550E FBL
Gaui NX4
Shuttle ZXX
Zoom 450 Nitro
DX18 Spektrum
renaud67
Re: Firmware DX8
Message par renaud67 » 27 sept. 2012, 08:58
Oui .. pour l'instant je reste en 2,04 :D
PIQUOOSE
Re: Firmware DX8
Message par PIQUOOSE » 27 sept. 2012, 09:02
pareil :ph34r:
orousseau
Re: Firmware DX8
Message par orousseau » 27 sept. 2012, 12:11
2.06 injecté hiers à première vu pas de souci. Reste à tester un vol
Image Gonneville sur mer, 40 ans, calvados
Image Goblin 700, Mini Proto,
Image Porket racer fpv, Nano QX
Image DX8 + Telemetrie, DX4e, EZUHF
Image Phoenix V4
Image Hyperion EOS 0720i Super duo3, alim 24 V 44 A
Image Phantom FX61 FPV, fy41,
fred57920
Re: Firmware DX8
Message par fred57920 » 27 sept. 2012, 21:15
2.06 installée. J'ai juste eu besoin de revoir mes courses et sub trims de mes programmes... (inter failsafe sur un multirotor avec Naza).
yak54
Re: Firmware DX8
Message par yak54 » 01 oct. 2012, 11:16
bonjour
de toute façon si vous avez installé la version 2.05 et retouché vos trims ,ce n'est pas la peine de mettre la 2.06 il ne l'a prend pas.
Salutations.
yak54 50 ans vie en lorraine
copter x450 , yak 55m , tucano ,yak 54, piagget ,sukhoi 26m plus tout ce que j'ai cassé
radio DX9 et dx8 (plus pour longtemps)
[email protected]
Re: Firmware DX8
Message par [email protected] » 01 oct. 2012, 19:20
yak54 a écrit :bonjour
Salutations.
Ha bon ! c'est nouveau ca ?
J'ai installé la 2.05 et j'ai touché a mes trims et j'ai ensuite installé la 2.06 sans aucun probléme .
Le probléme d'écolage est maintenant résolu .
Je ne vois pas le rapport des trims de la v2.05 empéchant l'installation la 2.06 .
Moi au contraire je conseil d'installer cette nouvelle version .
Ma flotte :
yak54
Re: Firmware DX8
Message par yak54 » 01 oct. 2012, 19:40
ben écoute j'avais la version 2.05 j'ai corrigé mes trims
j'ai essayé d'installer la version 2.06 il ne la prends pas et il reste sur la version 2.05
tu as contrôlé que c'est bien la 2.06 qui est dans ta radio ??
yak54
Re: Firmware DX8
Message par yak54 » 01 oct. 2012, 19:44
alors vous je ne sais pas mais moi maintenant sur mon compte Spektrum je n'ai plus que la version 2.06 de disponible je n'ai plus les anciennes versions ,qu'en est il pour vous ??
yak54
Re: Firmware DX8
Message par yak54 » 01 oct. 2012, 20:59
autant pour moi ,
je ne sais pas ce qu'il s'est passé mais quand j'ai chargé la version 2.06 il y a deux jours et que j'ai essayé de la mettre ça ne fonctionnait pas ,la je viens de la recharger ,déjà elle n'avait pas la même capacité (y a t il eu un bug je ne sais pas) donc la je viens de la charger et tip top c'est chargé et bien présent dans la radio ,par contre j'ai du remettre certains subtrim de tout mes appareils ,bon voila c'est fini y a plus qu'a tester en vol.
salutations.
yak 54
djembe
Re: Firmware DX8
Message par djembe » 30 oct. 2012, 00:54
salut à tous,
je suis en version 2.02 avec ma dx8 j'ai vu que spektrum en est à la version 2.06 du firmware
peut on installer la version 2.06 directement?
cela apporte quoi de plus?
Image Rocbaron , 43 ans , Var
[email protected]
Re: Firmware DX8
Message par [email protected] » 01 nov. 2012, 12:54
djembe a écrit :salut à tous,
Oui sans soucis .
Correction de nombreux bug et amélioration divers .
C'est plus que conseillé que de mettre sa radio a jour .
Ma flotte :
djembe
Re: Firmware DX8
Message par djembe » 03 nov. 2012, 17:16
merci [email protected], dès que je trouve le mode d'emploi pour faire ça , hop je le fait
a++
fred57920
Re: Firmware DX8
Message par fred57920 » 12 nov. 2012, 17:08
Il suffit de télécharger un fichier sur le site de spektrum, le copier à la racine d'une carte sd, d'inserer la carte dans la radio et de l'allumer... 3 min après la mise à jour est faite :-)
alita
Re: Firmware DX8
Message par alita » 03 mai 2013, 13:25
salut y a t'il quelqu un qui aurait encore un firmware en 2.04 pou dx8 ou un version 1.03 pour dx7 car j'ai des problème d'ecolage
Image 49
Image TREX 250 Pro DFC, AR7200BX.
ImageGOBLIN 380 , AR7200BX.
ImageGOBLIN 500 sport , AR7200BX.
Image en DX18 Mode 3.
Image Phoenix V4.
Zaadum
Re: Firmware DX8
Message par Zaadum » 03 mai 2013, 13:46
Je m'ai peut-être chez moi...
Je te dis ça par MP ce soir ! ^_^
TiTidom
Re: Firmware DX8
Message par TiTidom » 03 mai 2013, 13:51
Euh... sauf si ça a changé, chaque firmware (pour la dx8 en tout cas) est personnalisé en fonction du numéro de série de la radio, faut donc aller le chercher directement sur le site, via son compte.
TiTidom
Envoyé depuis mon GT-I9505 avec Tapatalk
tino89
Re: Re : Firmware DX8
Message par tino89 » 01 déc. 2013, 00:34
Petit déterrage de post ;)
Donc effectivement on ne peut pas installer un fichier trouvé sur le net dans notre Dx8...
Mais savez vous comment faire pour justement installer un firmware antérieur ?
J'ai actuellement la version 3.0 et je voudrais downgrade en 2.04 :?
Merci de votre aide.
A bientôt
Envoyé de mon GT-I9505 en utilisant Tapatalk
godjc
Re: Firmware DX8
Message par godjc » 01 déc. 2013, 08:34
Je ne pense pas qu'il soit possible de revenir en arrière.
Image - Libelle F3K
tino89
Message par tino89 » 02 déc. 2013, 19:15
J'ai cherché et je cherche encore, mais effectivement je pense que ce n'est pas possible de revenir en arrière.:(
J'ai envoyé un mail à Horizon Hobby, j'attends de leur nouvelle;)
fourniey
Bleuzaille
Re: Firmware DX8
Message par fourniey » 14 janv. 2014, 00:54
As-tu eu une réponse de horizon hobby
totof54fr
Re: Firmware DX8
Message par totof54fr » 20 mars 2014, 23:38
Salut, es-ce que le downgrade à était fait.
Moi j'ai peut-être une solution, tu insère la carte sd de la radio dans le pc, et tu efface les fichiers SPMTX SAX que ne veux plus, et normalement tu te retrouves avec la dernière version que tu as laissé sur la sd.
Je pense que cela doit fonctionner, à voir.
Christophe: 39 ans - Toul/Nancy - (54)
Spektrum DX8: neXt RC :D
Futaba T14SG: Goblin 570 12S - Oxy 3 4s - Quad Racer 210 4s - XK K110 - 2 x Funjet Ultra 3S - Héron Multiplex 2,40M - Crack YAK 55 - Chticat Racer 3s - Tiny 7x - Tiny 8x - Fly EGG 130 - Fatshark HD3 - Furious True-D - Spironet
Mes vidéos: http://www.youtube.com/user/Tof54200
Mon appareil pour filmer: http://www.panasonic.com/be/fr/consumer ... x1000.html
choupboup
Re: Firmware DX8
Message par choupboup » 19 janv. 2015, 21:48
slt les gars , dite simple question , parcque je vois que tous sont a l'afus des Maj , ayant encore le soft 2.4
ca apporte quoi quelques modif dans les menu ou au stick ont a un mieux ? pas que je me plaint de la mienne mais bon ^^
totof54fr
Re: Firmware DX8
Message par totof54fr » 19 janv. 2015, 22:22
Salut Choupboup,
La dernière MAJ date de Février 2014, et c'est la 3.01
Si mes souvenirs sont bon, cela intrègue un menu PLANEUR
Tu as aussi le rétro éclairage.
Mais je crois que c'est plus basé sur le mode PLANEUR
Moi j'ai la mienne depuis sa sortie, j'ai fais un retour SAV pour un CHECK, et RAS, elle me convient très bien pour mes modéles indoor et pour faire du simu.
Franchement, je ne m'en plaint pas.
choupboup
Re: Firmware DX8
Message par choupboup » 19 janv. 2015, 22:24
mwai le mode planeur pourquoi pas mais faudrais avoir une machine avec 6 servos dans les ailes alors ^^ ca ne me serviras donc pas , pour le reste je la trouve aussi parfaite concerant le retro eclairage , si cela consiste a le regler en intensité bof ... c'est pas un tv ^^
merci du detail !
